www.expediterworld.com
www.brummionline.de
www.truckstopaustralia.com
Results 1 to 5 of 5
Thread: Bunk Heater and Fridge not working
  1. #1
    Join Date
    Dec 2012
    Location
    Mississauga
    Posts
    13
    Default Bunk Heater and Fridge not working
    Hello Experts
    My 2006 Volvo 670 is having problem, Bunk Heater ( Webasto ) and Fridge ( Original from Volvo ) is not working. I need to know reference for some good mechanic who can repair the bunk heater and fridge.
    most people are not trying to look inside and suggesting to replace both. it is expensive solution.
    Appreciate if someone can suggest a mechanic ,Looking in Mississauga or Brampton area.
    Regards
    Hasan
  2. #2
    Join Date
    Jun 2011
    Location
    Toronto
    Posts
    345
    Default Re: Bunk Heater and Fridge not working
    For the fridge.. Buy a new one. Walmart sells them for real cheap and last a long time.
    For bunk heater... There are so many shops in BTown and Mississauga to choose from. Just be careful with whomever you pick.
    Class of 2013
  3. #3
    Join Date
    Dec 2012
    Location
    Mississauga
    Posts
    13
    thanks a lot.
  4. #4
    Amateur Surgeon Champion!
    Join Date
    Oct 2009
    Location
    Cambridge Ont
    Posts
    253
    Did they quit at the same time? It's possible they are sharing a wiring circuit. It'll be a whole lot cheaper to replace a fuse or rotten wire end, then to replace both items. If you do have to change the bunk heater, there's a place in the Ayr Flying J plaza that sells used/refurbished heaters. I believe it's $600 for a Webasto
    Posted via Mobile Device
  5. #5
    Join Date
    Nov 2010
    Location
    canada
    Posts
    159
    repair hmmm most time more as a new one ... see..
    https://www.wish.com/search/2kw%20di...2c48514a71c62d
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
