www.expediterworld.com
www.brummionline.de
www.truckstopaustralia.com
Results 1 to 6 of 6
Thread: Local GTA companies Hiring Owner Operators
  1. #1
    Join Date
    Dec 2012
    Location
    Mississauga
    Posts
    13
    Default Local GTA companies Hiring Owner Operators
    Hello
    I wanted to start local work within GTA as an owner operator. Need to know if there are any recommendations for local work.
    Now a days there are two models in the market , one is per hour rate and other is per load basis , more or less after calculating both it turns out that owner operator can get around $ 26 / hour. Provided truck runs 1200 Kms in a week and around 60 hrs /week.
    Thanks
  2. #2
    Join Date
    May 2011
    Location
    Scarborough, Ontario
    Posts
    4,327
    Default
    Quote Originally Posted by goraya View Post
    Hello
    Thanks
    I'll save you years of your life. At the end of the day you will put minimum wage in your pocket and repairs will come from that.
    Have a look at MET Motor Express Terminals.
    Posted via Mobile Device
    ..probably in one of my drunken stupors
    DRIVE FRIENDLY
  3. #3
    Join Date
    Apr 2011
    Location
    Home of the Stampede
    Posts
    2,229
    Default Re: Local GTA companies Hiring Owner Operators
    Please tell me that isn't $26/hr to the truck!
    There's a nap for that.
  4. #4
    Quote Originally Posted by lostNfound View Post
    $26 per hour as a DRIVER would be okay. As an owner/operator that’s a losing proposition. Move on, look elsewhere.
    Sent from my iPhone using Tapatalk
    A Christian Trucker’s Story of Redemption http://www.ShinySideUp.ca
  5. #5
    Join Date
    May 2012
    Location
    guelph
    Posts
    487
    Hello
    Thanks
    You do know what o/o means right? It means you own the truck and or trailer. Now are you talking tractor trailer or sprinter van? Not that it matters but 26 per hr won't cover either of those options. Its good to ask questions but maybe a little more specific question would help. Narrow it down a little. 26 per hr should be a drivers wage not an o/o.
  6. #6
    Join Date
    Dec 2006
    Posts
    9,571
    That's a bit below the prevailing GTA rate....$33 Is the number I see most time...which is a joke.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
